Supergyro
Active Member
Hello fellas.I'm running into a mental quandary with the application of the old axiom of "don't fix what isn't broken." I could use some help from you guys to decide which way to progress.
I had my CB360 running, but with a few issues. In my jubilant state I decided a test drive was in order, so I set out on a local paved road. As I would get into the higher RPM range (unsure of exact value, my tach was not installed for this little test run) the engine would bog somewhat, and at one point (by my inexperienced ear) seemed to run only on one cylinder. I was obviously concerned, but figured a timing and carb synch were in order.
Being one to rush into things, I started with the timing. I reset the cam chain tension, set the tappets, and went to set the points. I struggled with points for a while, replaced a few stripped phillips head screws with cap screws, and generally mucked about the process. When I was satisfied with my work, I went to start the bike and promptly broke the electric start mechanism! (motorcycles... I tell ya) Fast forward through scavenging an uncracked starter clutch puck-deal from the parts bike and I have the electric start back to functioning. But now the bike won't start. It's like a dry, unproductive cough... I can't get it to catch.
So at this point I think my timing job may be suspect, but I'd thoroughly enjoy never having to deal with points again. To that end I have procured a PAMCO e-ignition unit from Mr. Pete himself, and plan to do away with those pesky points for good. My question is, should I follow the old axiom of having a running bike before any modification? Or should I consider the PAMCO unit the cure to my issue and go forward with electronic ignition?
Any technical help, tips, or anecdotes would be greatly appreciated.
