so2002
Hey guys,
I decided to make a new post for my ’70 Honda CL350 K2 Scrambler, as the other thread was months old and over 10 pages long.
After putting in ~6 months of blood, sweat, and tears into this thing, I dropped it off with a mechanic. I haven't been able to get the bike running for more than 1 week at a time since I've owned it. I hoping that the mechanic would be able to fix the bike, but he just called me to say he has no idea of what is going on with it and wants to know if I should pick it up. (Currently they're tearing into the mechanical advance because I shortened the spring by 1 loop on each side)
I'm at my wits end, I love the bike and want to fix it, not sell it for a huge loss (of $$$, but also time and ego). I have to decide whether to pick it up or let the mechanic continue, but he says he's not sure what he should do next. :'(
Symptoms:
Bike idles and revs fine. Has very little power under load and is basically unridable.
Summary of knowledge:
Old Thread: http://www.dotheton.com/forum/index.php?topic=53402.0
Compression - 150psi on both cyl's
Fuel
Carbs rebuilt and rejetted
Fixed Carb Air leak
New JBM Industries diaphragms (didn't glue, should they glue?)
New carb boots
New Fuel Line
Petcock cleaned (no water inside)
Fuel Filters added (don't see any rust collecting)
Electrical
New Points
New Coils - Need to check them with heat method
New Condensor - never tested
New Battery
Rebuilt, cleaned, and shortened springs for Advance Plate
New Spark Plugs
New plug caps
I could use any advice you guys have. I work long hours these days and don't have time to tinker like I did before. Is there more that I should have the shop look into, or should I pull the bike from the shop asap?
Mike
Symptoms:
- Has compression (~150psi in both cylinders)
- Carbs have been rebuilt 3 times (twice by me, once by the shop), and rejetted by shop. Carbs have diaphragms from JBM industries.
- There aren’t any air leaks (shop fixed one that was there, says it’s good now)
- All the electrical components are new (battery, condenser, coils, points, plugs) and timed (with strobe)
- Shop says bike has spark
- Rebuilt Advance plate (chopped off 1 coil of the spring because it was stretched)
- Fuel flow isn’t an issue (cleaned the petcock, have fuel filters, new fuel lines), running with cap off does not help
Fuel
Fixed Carb Air leak
New carb boots
New Fuel Line
Electrical
New Points
New Battery
New Spark Plugs
New plug caps
Mike
