CB360 - Clean and simple
I wonder if this is how the valve got bent?
New rings! (ended up breaking one of the oil rings so I had to reuse one of the old ones :mad: ... they looked to be in good shape though)
0.020" on one cylinder
0.017" on the other
Seems right? square one on the top, notched in the middle, oil on the bottom (this is the used one) All the stamps are on top
One down
(not so) funny story trying to get the first piston in... dropped the C clip into the crankcase trying to put it in... How lucky is this?
Both pistons in
Clocked the ring gaps as such
Got the cylinders on as a bonus
Also started putting the side bits on
Looks nice. Before you put the head on, confirm that the smaller pitch of the valve springs is adjacent to the head. I can't tell from the angle of your photo.
Nice work on that engine. Looks fantastic. You might want to flip the valve springs, though. The tighter coils go closer to the head. :)
Nope, nothing better than that. I would modify further around next time and not so 'deep'
When I said I went too far, it refers to the spring seating.
The spring isn't supported in the area's I ground down to the inner wall.
In the picture of rings on piston, middle ring is upside down. There is a slight taper so it will 'seal' on the upstroke and probably pump oil into the combustion chamber
Thanks for the attention to detail! I realized that after I put it together but didn't get a new picture :-\
redwillissuperman said:
Did you do the "required" oil pump mod?
@crazypj might have better pictures
Not yet, it's on the list of things to do when I clean up that cover.
Are you sure? The manufactures mark is on top.. I have it set up like this
Top of piston
_
| <- Square ring on the top
|_
| <- Notched ring in the middle, notched side up
0000 <- Oil ring on the bottom
_|
Bottom of piston
PJ thanks so much! Turns out you were right, I pulled the cylinders off to check and ended up putting the markings facing down...
Unfortunately, one of the oil rings got jammed up when I was putting it back together and not only broke the ring, but scratched the cylinder
I honed it as much as I was comfortable and the ring gap is now roughly 0.024
It still catches my fingernail a little but I can't see light under the ring and it's and it's so low on the cylinder I'm thinking (/hoping) it doesn't end up being a problem...
Finally got it all back together with the last oil ring I have and then realized something.
In my quest to break all my rings, anyone guess where these go? :(
Cylinders had to come back off to put them on
At this point I was able to get it back together without breaking anything else - pistons move smoothly, hopefully no more drama.
Too much carnage for one night
Following the theme of forgetting to put stuff where it goes...
I also got a new one of those castle washer things since I sheared one of the teeth getting the old one out - it'd probably still work but might as well replace it
Everything in where it belongs
Seems I don't have a new o-ring for the oil filter so I'll have to order one of those.
Got the clutch put back together too
Took some time to clean up the space, put down fresh cardboard, make sure I didn't end up with surprise left over parts etc.
Lastly, I couldn't help but to take a sneak peak of how it will look assembled - I'm debating if it's too much of the dark color on the side ???
Took me 3 or 4 tries to get my 360 engine back together the first time, I feel your pain.
The paint scheme looks a bit backwards... It might look better with the darker shade on the crankcases/top end and lighter color on the side covers. Or, polish the sidecovers and keep the color of the cases as they are now. Just my .02
Large O-rings around cylinders.
As long as your 100% sure the oil rings are installed properly on the pistons AND believe the original O-rings are in usable condition.
I wouldnt be too concerned about installing new o-rings now, that shes already gone together.
Yeah, still debating about the color - having media blasted the covers, I'd have a long way to go to polish them... we'll see
The issue was that I had already removed the old ones... they were pretty rough. It's cool though, already took it back apart and got it back together with the new o-rings
I would have the cylinder honed and get new rings to gap. You are going to have compression problems.
I hope not. I think it might look worse than it is... Plus, at bottom dead center it only shows about 1/2" above the piston, so hopefully it's far enough away from magic that it doesn't cause problems
Thats a direct path past the rings called blow by.
Get an oversized ring pack, hone the cylinder, and file fit New rings.
I'm going to put the head on and then do a leak down test - that will let me check my valves too. If I'm getting reasonable readings at bottom dead center (comparable to the other cylinder) I'll just leave it. Have to wait for the new valve to come in though.
In the mean time I made this unboxing video...
https://www.youtube.com/watch?v=YTfLc9238vA
Mail time!
Since valves are expensive and I only needed one, I found this head on eBay for $30 with all the valves!
Unfortunately, one exhaust stud was broken off in the hole and the other hole was broken out of the head :(
Also I think these fins got broken in shipping as they weren't listed in the auction
Regardless, it had what I needed:
Some cleaning and it looks pretty good
A quick lapping put a nice fresh mating surface on it
All four valves are in now, yay!
Except in my mission to break all the rings, who remembers where these go? :mad:
Yep, cylinders had to come back off...
...and back on
Fresh head gasket 8)
Guides and guide seals installed
Head in place
Cleaned these up a bit
Hand tight
Getting closer! :D
P.S.
This was in the new head I got, any ideas?
P.S.S
Anyone have the torque specs and tightening pattern for the head bolts? Leak down test to come once I get everything torqued.
If one is really dead set on welding those fins back straight, it can be done. Ask me how I know... :-\
And that little 3 ball clutch lifter component is pretty valuable. They're prone to warpage due to misadjustment of the clutch mechanism. If yours is in good condition you may be able to resell it.
Nice!
Supergyro said:
Tightening sequence and torques from the shop manual.
This is perfect.. thank you so much
