wow...a bout 10 hours of soldering and lighting work... done done done done... each wire is also wrapped in braided sleeving... came out PERFECT!!!! also set it up so that it is all on plugs now, so i can unplug and remove all the tins... will go much faster if i ever want to pull them off again... almost there!!!
tank is on, flush mount guage and fill are installed, flush mount fuel guage is much brighter and easier to read than i would have thought
Did the mud mod to my stock football, and coated it gloss black, blue bolt and it flows very nicely... much better than the old set up
got rid of the ugly horn bracket from the side of the motor... and used a small pancake horn, made a bracket and moutned that up
next up was rear lighting... added some driving lights to the swing arm to make sure traffic can see me, these are tapped into the brake lights as well to get brighter when i brake
running
brake
turn sigs wired in (used micro LED's) and also tapped one into the mother board for brake light for a bit added light
then it was time to lite em up
here are the pics
front tire
side pro 1
side pro 2
running
brake
here are the pics
front tire
side pro 1
side pro 2
