Sonreir said:The neutral light circuit is a fairly simple one, in case you need to replace it.
The bulb on your dash gets power from a black wire. The other wire from the indicator light runs directly to the green/red wire coming from your alternator.
el barto said:Few bits today, mainly electrical with the kind help of Sonreir - finally most of the electrics are done.
Lil spray booth I cleverly knocked together (could also double as emergency underwear?):
Getting fuck all done while on dad duty:
el barto said:Cool, so I can just leave that wire I was referring to loose?
Sonreir said:If you don't need or want your neutral light, yes.
Sonreir said:Yup.
Sonreir said:Depends mainly on the brand and the model of the lights in question, but LEDs usually run between 3W and 5W and incandescent are between 20W and 25W.
JustinLonghorn said:Grease Gun. Air compressor. Drill a hole and hammer it out.
