Dreadnotred Hellride chopper
Front caliper sorted with a Tokico that came off an EX650. The 750f fork mounts were within an inch from the caliper mounts, so it just required a small bracket to move the bottom hole, while still using the top hole. Then two spacers were machined to match the offset.
I had a blast with the wire wheel digging through all the bondo on a smoothed out 70s chopper frame in all the usual spots, only to find no numbers. Looks like we’ll do it by the engine number...
I changed my mind and decided to run a dimpled tank. Anything in front of the down tubes runs the likelihood of interfering with carbs/air filters.
pidjones said:
Except that I've never seen a "matching numbers" Honda.
If I recall my CB360 engine and frame #s match. Currently stored in my neighbors garage so I can't look at the moment.
I wish I had a neighbor that let me store stuff in his garage.
