That rear tyre though...that's going to be shit scary when you tip into a corner...it's like a knife edge! Looks more like a car tyre with that flat profile.
this is what i use if i need performance and wild turns, i can't se the rubber problem its not flat on the top its curve a little but thanks for the cons urn
First of all, the bike is not comprehensive but only set up and form a picture of where I'm headed towards . swing arm is extended and behind the springs need to be higher so the angle of the bike also gets really , the wheel will never frame and the rear frame I put rubber pad into the rear shock as bump stops . but thanks for the input the fat is so helpful ,
look at the picture the rear wheel is also turn the wrong way the brake is in the wrong side its only to see the look
