stevenfrye
Bwahahaha smart enough to be dangerous ect.ect.ect
If you want a high volume and pressure pump hit up your local pick a part and see if one of the sports car units would work for u, and I've messed with Gm one in the past go up to 60 psi some Bette units go as high as 80 wouldn't be hard for fora good welder to put in tank for u. Also with that run a loop bypass with an cooler built in it
