Dyna Ignition mod CL175
ApeMummy666
Installed the GL1000 dyna ignition on my CL175 with info I found on the forum. Everything works great, I'm just wondering a couple things. First, the screw that holds the plate on the right side no longer has room for a washer, and without one it's just barely holding on (see pic). What have others done? Also, should I just cut away the wires for the unused right side trigger, or can I just leave everything in there? Thanks.
White wire can be trimmed down but the power wire should be shortened and then capped with shrink wrap because it's live.
On the pickup module, I would think you could grind some of the molded plastic away where it gets in the way to get more space and then use a small(ish) diameter washer.
