Seems the dealer is the problem (?) - have sent the insurance certificate again today and hoped for the best
Need to get out to see if my straight through megaphone is too loud !
Have taken my swingingarm out and measured the spacer , 17.9mm , and greased the bearings - seems more play in the bearings than I'd like . Tried to shim the ends but the problem seems to be that the spacer is undersize for an 18mm i/d needle roller ?
The sticking up reflector seems to have "fallen off" mine
and as mentioned the nuts/bolts seem to gall/seize not sure if its their quality of surface finish/lack of lube .
