2001 GM Bailout....
DesmoBro
Busted Nut
Brake line blows out ....Mint......gonna need to bust out the Welder
No Pain No Gain....Gained 100 lbs of blasting media before i welder up!
Did a double sleeve ( inside & out)on the shock mount side
Project had stalled out until i got this bitchin airhammer today....grabbed some 2500 HD rear leaf springs from the junk yard $150 for the pair last week and couldnt move the studs.....couple minutes with the air hammer and project commence! Gonna either paint or undercoat these maybe find new bushings too while i look for bolts
Just starting to come together
Tomorrow .....I might.....put a few coats of black on the straps in the AM and hope it dries enough to install the tank by 4:00......once the tank is in again , hook up battery and it should be ready to daily again once the bed is put back on and gas is in line hooked up etc etc....you realize how little one quart of paint is with a project like this
Been dreading working on the rear bumper but finally got started on it today and only had to cut off one bolt
