Anyone running the Pamco electronic ignition with e-advancer?
I ordered the kit, but undecided if I should install it due to the problems I've read about (one cylinder not firing, etc). Any feedback from someone who installed it? How has it ran on you?
Also, all of the images of the kit installed, show it up exposed to the elements... Is that how we are suppose to ride around? Or does the cover fit on top just like over the points?
I run Dyna on most of mine, as well. I've known people with good luck with the PAMCO, but I can't speak from personal experience. I also have a buddy running the Tytronic ignition with great success. And I have a buddy that built his own with sensors from a Toyota distributor and GM modules. They aren't that complicated. Personally, I have no issues retaining the mechanical advancer like with the Dyna or Tytronic. As long as the springs are in good shape and it's kept clean and lightly greased, it works well.
I had a Pamco on my 450 (without e-advance). I just replaced it with one from Charlie's place. The Pamco rotor had excessive wear where it interfaced with the advance mechanism. I had to have my first unit replaced because it didn't work. Second one worked fine.
I'm glad to hear that others are at least using electronic ignitions. I already have the Pamco unit w/ e-advancer, so I'll give it a shot and see how it goes.
So once the e-ignition is installed... before I set the timing, I need to adjust the cam chain and adjust the valves, correct??
Right, but some manuals say to do it with the alternator cover off, while the Honda manual says to losen the screw and retighten while the engine is running??
Which is better?
...and do I have a screw missing?? (See attached photo, has a screw where I dont..?)
Is there nothing in there at all? There should be a spring loaded rod with a pad at the end that pushed on the roller mechanism against the chain. It's not a big deal removing it from the motor to inspect, just make sure you have a gasket or make one.
Yeah. The set screw holds the rod. When you loosen the set screw, the spring forces tension and pushes the pad towards the wheel and puts pressure on the cam chain. So, it's totally conceivable that it's in so far you can't see it. Personally, I've never seen one that deep although my CB750 is about 10 - 12mm deep.
Ok, so the adjustment screw and bolt are the ones on top, but the screw I'm missing holds the rod in place which actually puts the pressure on the cam chain?
Do you know the exact names of the screw and rod in case I need to order them?
You have everything there. That screw on top holds the rod. The bolt holds the screw and prevents it from vibrating loose. Stick a small screwdriver in the hole and see how far it goes in. The rod is probably there. If not, you can probably buy a whole new used unit for cheap enough on eBay. I don't know exactly which bike you have, but you can look up a schematic and order the missing part if it's missing.
