75xl350 said:im working on a honda xl 350 and i got the back lowered but how do you go about lowering the front? theres no room to slide the tubes up in the clamps because of the handle bars. and info or pics would help. thanks.
AlphaDogChoppers said:The correct way to lower a fork is to add a spacer or a spring to the rebound spring on the underside of the damper rod. Then you have to adjust the main spring preload by shortening the spacer at the top of the fork, or shortening the spring if there is no spacer.
There will be plenty of people who will simply say to shorten the main spring spacer, but leaves you with saggy forks that have no preload. It's a setup that is far from ideal from the standpoint of handling.
teazer said:ADC's approach is perfect for a drag bike or one that has too much travel (like a dirt bike). Probably a more suitable way for normal bikes (without a lot of travel) is to buy shorter forks or to machine the tops and springs shorter.
