jcharny
I painted my calipers with VHT SP739 Satin Black Caliper Paint last night. The instructions were to apply 2 dry coats and 1 one wet coat within 1 hour, allowing 10 minutes between coats. The instructions also say, if additional coats are needed, wait 7 days before applying more paint. VHT caliper paint must be cured at 200 deg F for 60 minutes- they're currently in the oven. My question is, if I cure them, do I still have to wait 7 days to apply additional coats of black or VHT's caliper clear coat? I can't imagine the proper application is to wait 7 days, apply additional coats, THEN cure in an oven? To summarize 2 questions:
1) Can additional coats of VHT caliper paint be applied AFTER curing at 200deg F?
2) If yes to the above question, do you need to wait 7 days to apply additional coats or is the 7 day waiting period ONLY NECESSARY if waiting to cure with heat after all paint has been applied?
Thanks,
JMC
Thanks,
JMC
