1977 BMW R100/7 Sarcoplasmic Cow Hellride
Re: 1977 BMW R100/7 Miles Von Muncher Hellride
Gonna try a 3AN setup for the front brakes. It's an odd length for the custom front end...
I was starting to wonder what you been up to. ;)
No hardware for the rear brake, except the thumbscrew, so I made my own...
... until I buy the stock bits.
Its a "Work of Irk"!
See what I did there? ;)
Nice work as alway Irk. Keep te brake bits you made, prob as good or better than stock. Put the thousands you save somewhere else lol
I was just making these exact parts today. great minds think alike I guess!
Every time you do right by this old gal I feel better about sending her your way.
I put about 40 miles on it yesterday. Slowly tuning it up, but it's running really well otherwise. Got the carbs close on sync, but I still need to do it proper. After a good heat up, I discovered my oil pressure switch leaks. Ordered a VW Bug switch to replace.
I also just received the R100 throttle I ordered so I can delete the cable operated under tank m/c...
eric where did you order the throttle i need one for my r80
It's a used throttle that I got on eBay for $150. MaxBMW sells complete units for $263, but you'll need the face with the switches to swap over.
http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=51664&rnd=12082016
