treitz said:Ah cool. Didn't realize you were going mono-shock. I'm going mono-shock on my XS850 cafe. Fun stuff!
I checked out your build, lookin good!
Bigsherm said:Wow, that's seriously good so far, but only the manliest of men is man enough to ride that king and queen seat that came on the bike.
You gotta keep that!
-Sherm
jpmobius said:Really enjoying this. You have so little left of the original frame, hope you have an "empty" motor to line up the bits you have left, the fully built one will be quite the pain to shift in and out while you complete it! Beautiful work and a nice elegant jig. Looking forward to future installments. I hope you will elaborate on how you plan to determine the elevations of the swingarm pivot and the two axles. No doubt tuning the springs will be the end of the process, but you must have a percentage suspension sag target in mind so I am hoping you will explain your process for setting this up.
johnu said:This is very nice work, you attention to detail is quite rare, you and I could work well together because I too work in this manner. I will be following along with interest. I once bought an XS650 for a project but sold it just because of the weight of the thing, as I recall the engine alone is around 150lb? Anyway I look forward to seeing more progress.
Bigsherm said:NCO-
Don't let your plans go!
If you really want a monoshock, don't give up on that!
You obviously have the abilities, brains, and facilities to get it done right.
It would be sweet with dual shocks, but it'd be a shame for you to wish you'd done differently after you're done.
-Sherm
ncologerojr said:It has been very, very cold in the workshop lately, but I got to work on some geometry today. Here is a drawing with the gsxr forks (720mm, 30mm triple offset), 18" wheels, swingarm pivot in new planned location ( very close to stock), and stock 27 degree neck rake. This seems to give me a good base swingarm angle, and trail numbers. Once the bike is assembled I have room for adjustment.
johnu said:It is really simple to make monoshock ride height adjustable with some kind of turnbuckle arrangement depending on your setup. Also don't forget to get your countershaft sprocket centerline in your drawing as you will probably want to get your swingarm pivot as close to the sprocket as possible and also on the the same horizontal axis if possible. Keep at it !
