josephau said:hi guys, need some advices.
my ace would not start on me this morning with electric start but kick start ok. i think i can hear a funny clicking noise from the selnoid starter which i'm not hearig before. could it be the starter or loose wire?
joseph
krazed0451 said:I would suspect a poorly grounded wire or dead/dying battery.
krazed0451 said:Strange that this should be my first post...
Hi mate, year that pipe from the motor is part of the anti pollution valve . there is a plate from ooracing (or you can make your own out of 3-4mm thick flat bar) to block off the outlet, then you need to block off the hose connected to the top of the engine inlet manifold (it goes to the valve that the pipe goes too, bolted to the frame )gecko said:Or is there a modification that removes the pipe work to the right of the spark plug
I should also point out part of the reason for me in getting one is so I can work on it myself and learn a bit more about how it all works
So thanks for any help
Gecko
Son of a Gun said:looking to get a NGK spark plug. which one would be most suitable/ how would i find that out myself?
