Honda "l'arancio dolce" CB 750 Resto-Mod Project
2_DONE_THE_TON
Over 1,000 Posts
DTT BOTM WINNER
Hey guys!
Looks like I got a new project!A good friend of mine asked me to help him with the resto-mod of his CB 750.
He has 2 ex-police Cb 750 bikes in his barn and wants to make one fully working nicely refurbished bike out of it.
Yesterday we took some time and started checking the bikes:
Electrical system seems to work to 80% (hi/low on the headlights,oil pressure,blinkers left and right,blinker relais)
Not working: Starter button,no spark,neutral light-->We checked the fuse box, all fuses are ok?
Any ideas how where to start on the NO SPARK problem?
Starter button is dead too, any ideas where to start on that problem?
We took a screwdriver and bridged the starter relais, the starter motor turns nicely with a fresh battery and the motor seems to have good compression (will check with a tool next time, what should this motor have psi wise in compression?).
Any advise in the right direction would be appreciacted!
First up will be cleaning the carbs and getting a spark going!
Motor:
CB750E 2734730
Frame:
Cb750K 2733839
Is it normal that frame and motor number do not match up with these hondas?
in the registration papers it is the same,just asking since on my old yamahas the numbers normally match up.
This is going to be a full rechrome,powdering the frame full-on resto...lets see where this will lead us!
Thanks in advance guys!
8)
Most excellent.
For no spark, start running through the ignition from the plugs back which means check the resistor caps. The F model I helped get running recently had just that problem after sitting since the 80s. The resistor caps showed infinity on the meter. A quick change with a new set of caps and it fired up.
Your starter button issue could be the neutral switch. Did you have it in neutral with the clutch pulled in when you started it up?
And as far as the frame/motor ID, they never matched on Hondas. That motor number (CB750E) tells you that is a facelift model. E for European because Honda added Euro features.
By those carbs, that looks like a 77 or 78. I'm not going to lie. Those carbs are a bitch to get clean because of the accelerator pump circuit. Once they're right, they're awesome. Also airbox for that year is only for that year. It has a notch for the choke that other years don't have.
I hope you guys have fun with this one. I still love the 750s, even though I turned mine into a chopper.
Re: Honda "l'arancio dolce" CB 750 Resto-Mod Project
I wondered what year also. I have a 77 Honda CB750K that was going to clean the carbs out this winter.
irk miller said:
Most excellent.
Thanks Irk for jumping right in!
Had bad sparc too on my XS750 project,ended up switching out caps,cables and ignition box.
Is there a way to measure the plug caps (you stated showing infinity) with a multimeter?if yes hwo doI need to set the mulitmeter up?thanks!
Pull the caps off the wires, put one lead in the wire end and the other lead in the spark plug end. Set the meter to 1k ohms. For a 76 or later, they should read 10k ohms or less than 11k. Any more than that and the caps are burned out. Pre-76 will be 7.5k ohms and are burned out at 9.5k ohms. You can get replacement NGK resistor caps at 5k ohms and improve spark. It's not a bad idea to do it regardless.
Thank you irk!since we are doing a full nearly total resto we will go for fresh plugs and caps!I will however measure just for fun the caps!
As for the carbs: I´ve already been warned that these carbs are a nightmare.How would you go about?
The carb slides are stuck and don´t move a bit, the bike however was well stored (the tank inside is immaculate) and I have hope that the engine won´t need a total rebuild...
My friend Der_Nanno advised me just to take the bowls off, clean the main and idle jets and leave the other things alone.
But I guess this won´t help me with the stuck carb slides....
I have access to a ultrasonic cleaner, but throwing the whole rack into the bath without "top end" dissassembly of the carb will probably ruin the carb i guess...
Just cleaning the main and idle jets doesn't usually work on these carbs. PD carbs are unique in a lot of ways. The biggest issue with these carbs is the accelerator pump circuit. It's prone to clogging when left stored for too long, and it's vital to the performance of this motor. You can try to spray through the circuit with carb cleaner, and if you're lucky, it will work. But you need to get full spray on all for carbs coming from the pump nozzles. The tendency is for #2, which is where the pump is located, to clear and the fluid just stream through that circuit. The pump circuit is the rubber tubes that run between each carb.
Thanks Irk!That sounds really complicated...cleaned already a lot of carbs but never a bank of four with a pump...thinking about outsourcing this to one of few firms that specialises in overhauling these carbs...will cost some $$$ but since the owner is prepared to invest I think this is the way to go.
Is there someone in the forum that offers this service?
Do you have recommendations?
Thanks!
You can do it. It's more a pain in the ass then it is complicated. Check the pump circuit first. I may not be that bad. That said, paying someone $150 to rebuild these carbs for you might be worth it.
Yep,I will try, lets see..just had a word with a firm that does oldschool inline 4´s and they charge around 500$ for that job....
Well, yes there is.
With regards to no spark: clean the points and then follow the procedures. Checking plug caps, put the multimeter in resistance mode and set it to 20k. Caps should be around 5k. (Don't worry if they show 4000 or 6000, that's just down to the inaccuracy of cheap multimeters, as long as it shows some resistance, you're most likely fine.)
'77 750 shouldn't have a clutch or neutral switch cut-out switch.
Be aware that the exhaust, if polished up, might be quite sought after. If reasonably rust-free as only the early versions are available as replicas.
der_nanno said:
Well, yes there is.
Stock resistance on the 1977 plug caps is 10k ohms. They left very little room from being good to being burned out. 5K is what the NGK OEM style replacements should be. Also, 1977 model does have a neutral safety switch and a clutch safety switch.
Hey guys!
"neutral safety switch and a clutch safety switch"-->does that mean that the bike won´t have spark if started in 1st or any other gear?Irk could you elaborate?
Nanno, the exhaust (OEM Honda,we have 2 sets of them) is in amazing shape,it will however get a rechrome,since the back ends are corroded and need a repair.(see pic).
The first task will be getting the bike to start and run a few strokes.
New intake rubbers (I hope I will get the carbs out of the hardened old ones,heatgun will help),cleaning the carbs and points,probably new plug caps,plugs and plug wires and fresh gas,lets see what happens :)
Check the sidestand and the clutch lever. If there's (electrical) cables, you actually have a cutout switch. With the bike obviously being ex-Austrian-police-spec, I doubt there is. Normally such would prevent the starter from working and not the ignition.
I don’t know the nuances of a police spec 7fitty, but you normally need to have the bike in neutral with the clutch engaged to get the starter to turn as der_ nanno said. You still get power to the coils, so that can be checked with a meter. I swapped out for a different solenoid to bypass my safety switches, but you can also install a jumper. I’m not sure how the police version would’ve done it.
Engaged clutch? Wondered why mine just spit gas out and didn’t turn over. Didn’t know that was an issue!
My floats were stuck and couldn’t get them and a simple “clutch pull” hopefully will be nice. Thanks.
ATTENTION ATTENTION ATTENTION 8) 8) 8)
Reopening the thread...the projekt is in full swing.The bike already got transfered into my basement and the first works started on the dirty old girl ;D ;D ;D
Its a former police bike so I will be swearing a bit while I do this project in order to de baptise the bike...no good police stories in Austria.
The first stop will be making the bike run.The carbs are now off for cleaning.Checking for spark and checking the electrical system is next.
Any Advise is like and needed for this looooong run..I´m doing this beside my day job so go easy on me :D
A few pics.
First up the carburetors... Starting disassembling and sorting the parts.
I ordered rebuild kits. The carb is being disassembled and ultrasonically cleaned.
Gesendet von meinem EML-L29 mit Tapatalk
Carbs are dissassembled and now the search for the O Rings start.
The Keyster rebuild kit have 4 O rings plus the big O Ring for the float bowl.
I located a few already.Where do the the other ones go?
EDIT: Looks like 2 Orings go where the brass pipes connect th 4 carbs....Since I´m not planning on splitting the carbs these will stay.
The carbs now get soaked to get the most crud of then they will be ultasonically cleaned.
If you guys have any special advice on what to look out for It would be very helpful.
The first aim is to start the bike but not without changing out the old oil and oil filter.
And, if you have a leak on one of the cross-over tubes, you get to pull the rack and separate the carbs to fix it. Might be best to do all of that now.
