Hi - Im new here and wanted to share my new project.
I went to a freesale a few months back and fund this little gem in the back of the garage that the over signed over to me for $0! It was missing the piston and then on closer inspection the motor casing had cracked on the sump plug. Im keeping an eye out for a new motor and have seen some ranging from $150 - $250 so considering this has so far cost me nothing its a worth while investment.
So my plan is to build it into a Tracker/Brat style build. My first task was to strip the whole thing back to the frame clean, treat and respray the frame.
Nearly all apart...
Respray in progress
Ive also cleaned up and sprayed the fork - with new dust seals on order, stripped and resprayed the tank in grey metal flake and started to reassemble.
I was measuring up the rear fender here, my plan is to cut it shorter then fit a smaller brat tail light, as its a pre '73 I can get away without turn signals, though if I can successfully convert the electrics to 12v then I can put an LED tail light with built in turn signals that will keep the look that I want.
This weekend Im planning on starting to build up a seat pan, Im hoping to not have to chop the frame braces off, although I may lean it a little taking of the old seat hinges.
It would be great to get some feedback from experienced customizers on here as this is a first time project as well!
Nearly all apart...
Respray in progress
