Upgrade to a set of tapered roller bearings. They will be "thicker" than the ball bearings, and may eliminate the need for a spacer. If not, at least a thinner spacer will be needed.
I bought a P-nut tank from low brow but my measurements of my back bone were off and it just didn't fit. This frame seems particularly unsuited for most of the bobber/chopper tanks out there. This tank that I have does have a wider tunnel than most of the others so I may just run with it.
Long time no update. I’ve been slowly doing a few things. Ordered some parts and finally got them in. Picked this little tail light and mounted it on the fender. I’m not 100% sold on the look of these bars but the feel comfortable to me which is important. I can always change them later anyways. The headlight ears I bought are way too long. I’ve got this mount for a bottom lug headlight that came with the bike so I may get a bottom mount headlight, not sure yet. The rear tire wouldn’t hold air, turned out to be the tube leaking so I had that replaced. Still plugging along and hope to do more this weekend.
