www.Moto-Madness.com
Author Topic: Gasket Scan Library  (Read 21418 times)
Offline Pod70
Re: Gasket Scan Library
« Reply #20 on: Mar 05, 2013, 13:31:52 »
I hate agree with Bert Jan, but it is very likely that the print out will be scaled in some way and not fit. We have this issue at work trying to print out scale drawings of buildings we are working on. This is why all technical drawings state not to scale from the drawing as they will be out of scale-sorry
Offline davidgwells
Gasket Scan Library
« Reply #21 on: Mar 05, 2013, 14:37:37 »
The scans shouldn't be scaled as long as the user leaves it at 100%.  If you have access to adobe illustrator that program can print full scale and span pages if needed.  I'm sure there are other programs that will too, illustrator is pricey.
Offline Bert Jan
  • Holy Modification Batman
    • Outsiders Netherlands
« Reply #22 on: Apr 04, 2013, 21:58:27 »
1mm is to much differnce for a gasket... Besides, i have never seen 2 printers of different make and model print the exact same print. I went to artschool (university) for 4 years and work daily with CS and pricey printers. It's always a pain.
Offline Hoosier Daddy
  • Earache my eye...
« Reply #23 on: Apr 05, 2013, 09:16:48 »
Damn... Wouldn't a .pdf instead of a .jpg or .gif take care of this? Or is the issue with the scaling due to the individual printer?
STAY CLEAN '67 BSA Spitfire
ROCK-IT '81 CB750C
BOMBER '81 GL1100
OVERKILL '80 GS750
NO CLASS '72 CB450 K5
Offline Bozz
    • not nearly cool enough website
« Reply #24 on: Apr 05, 2013, 12:16:20 »
There will always be issues of scale when printed, as it is a printer driver level issue.
One way to minimize this (not eliminate, but minimize) is to include a scale object in the scan.
A little grid or square that has been confirmed with a ruler with the size of the object/pattern written on the image.
That way the image itself contains an internal scale reference.  Print out the file and measure the scale object within the image and see how off you are.
Cheers!
-Bozz
(All opinions worth less than you paid for them!)
05 FZ6 - 99 ZRX1100 - 93 GSXR750 - 82 GL500 - 78 GL1000 - 77 KZ900 - 77 CX500 - 60 R60
Offline Worst cb650 ever
  • You can always get it running with time or money.
« Reply #25 on: Apr 05, 2013, 15:50:38 »
Yup, I put a ruler on the scanner glass with mine.  Still didn't help when I didn't set the scale to 100% to print it out.
Remember that scene in "Innerspace" where the bad guys get shrunk down to about 4' tall?  Yea, like that.  Protip: lay a ruler on the scan on the image of the ruler in the printout.
DTT Blue (cause Winter is Coming) CB360 Club.
1995 CBR900RR - a winter flip not worth a DTT writeup - Sold
1986 Yamaha SRX600 - mailed to me from California - build coming soon?
1983 VF750F
1976 CB360T
1993 CBR900RR - Sold
1979 CB650 - Sold
Offline orlowskij
  • The wildcard
« Reply #26 on: May 31, 2013, 13:08:17 »
Damn. I wish I would have seen this a few days ago, I just installed most of a full KZ400 set. I think it's a good idea, and with a scale in the scan you should be able to tweak the print/scaling settings to get it right. I'll try to get the ones that I have left.
1979 KZ 400
  • Earache my eye...
« Reply #27 on: Jun 02, 2013, 08:38:05 »
Did this a while ago as a test at home after realizing the scaling issue myself.
So here is a test for you. Since it is an attachment you should be able to "click" on it and see it full sized... then print to test.
ROCK-IT '81 CB750C
BOMBER '81 GL1100
OVERKILL '80 GS750
Offline BarnBurner
« Reply #28 on: Jul 24, 2013, 17:14:58 »
I just got new gaskets for my CL175 to fix some minor oil leaks, so I thought I'd throw them up here for the good of the order. The dimensions of the graph paper when originally scanned were 1 inch (bold lines) and 1/10 inch (light lines), but when I printed it out it was slightly off. So, I'd recommend printing a tester then adjusting to scale for accuracy in your printer settings.
1969-1973 CB/CL175 Alternator Cover Gasket
1969-1973 CB/CL175 Left Crankcase Cover Gasket
1969-1973 CB/CL175 Tach Housing Gasket (fits behind housing not cover)
Hope it helps!
Old motorcycles never die, they just wait.
1971 Honda CL350
1968 Aermacchi/Harley Davidson Rapido
1967 Ducati Monza Jr. 160
1966 Honda CA100
1965 Honda CL77
Offline joevirus563
« Reply #29 on: Jun 19, 2014, 10:00:48 »
Need cb450 please :)
