Okay, so I just got a set of clubman bars and the throttle control (with the kill switch, start button, etc) and the front brake w/ the master cyclinder just wont fit on the bar together.
So this is what I would like to do.
I would like to get a small univeral throttle like this one (just scroll down on the page):
http://www.crc2onlinecatalog.com/Index_Main_Frame.htm.
This would clear up some room so that the front brake assembly would fit. Then I would just need to relocate the headlight and kill switches and the start button as i would no longer be using the stock throttle assembly. But, does it matter what kind of switches i used. Can I just get basic toggle switches for the headlight and kill switchs and if I get the right kind of switch can I just plug the same wires from the wiring harness into them (I know each swicth has two wires from the stock harness and ground and a power). What kind of switch would I need for the start button, so that I could plug the stock 2 wires into the new switch?
Thanks for the help guys, I know nothing about this electrical stuff.
