ceebeehead
Howdy good folks. I hate to be one of those people who just come here to ask for help without being able to reciprocate, but I'm coming to my whits, and knowledge's end. I'm having a baffling issue with my bike. Under load, often from a stop or while already in motion, from 2800 - 3200 rpm or so I get a rapping/rattling that goes away as the speed increases and load decreases from what seems like the upper area of the motor.
.. Edit...
I neglected to mention that it happens only at operating temperature. So far.
It's a completely stock bike set up (as far as I know).
--Carbs have been cleaned, bench and briefly vacuum synced before an intake leak caused issues then fixed. It idles fine enough around 1100 rpm after it warms up now. They were inspected for proper slow jets and float level. I haven't found an intake vacuum leak as of yet.
--Cam chain has been adjusted, still noisy. Fresh oil change with 20/50 motorcycle oil for fear of oil starvation at the top end, still noisy. Valves have been adjusted twice.
--Spark plugs are Champion equivalent of D7EA. NGK on the way.
--I put in a blend of 94ish octane gas, still noisy.
--The drive chain has been adjusted to spec, still noisy.
My unknowns at this point are the carb needles, size, taper and clip settings, engine internals as in pistons or upgraded cam. It has a Martek electronic ignition which I finally got to checking.
--The initial timing seemed to be set waaaaaay advanced, about 10 - 15 degrees. I have a video of just after a small adjustment then after timing was set to what I hope is spec at idle. The advance mechanism is also working when I checked it. Still noisy. :'( :'(
I was told that the PO had "raced" this bike at some point and gave me 1/8 mile times and such babble.
I've scoured the internets for honda cb engine noises similar to what I'm getting but it's all cam chain this and clutch rattle that, nothing like what I've got. Before tearing this thing open and dropping a bunch of money, I'd like to know if any of you can give me a direction or better diagnostic methods for identifying and repairing. I was able to record said noise and hopefully it's good enough quality.
I'm afraid of it being the primary chain hitting the case, I haven't yet dropped the pan for inspection. I also suspect the cam cover and rockers, maybe a bad spring.
I hope and pray that any of you can help. Thank you a million times and may you have many beautiful and masculine children.
http://youtu.be/aeypOaEaYC0 Rattling noise 1
http://youtu.be/7Ha_hT-Wo5s Rattling noise 2
http://youtu.be/3t4kqG--RNE Timing after slight adjustment
http://youtu.be/eA-QCm8-CD4 Timing at final setting
.. Edit...
