I got this bike a while ago and it has never run correctly.
The carbs are clean and the bike doesn't like to start in the cold. It will either start or just run the battery dead.
When it does start, it has to warm up for 10 minutes of running or else when I hit the throttle, it dies and I have to put the choke back on and start it again. I can't get it to rev without the choke until it's super hot!!
after that there is a good idle and good high end power, but nothing for low end, causing me to have to rev it to 5 k every time I take off from the start.
when I get into second I better be damned higher than 3k rpm, or it'll bog and kill.
I replaced the carb to engine boots and fixed the vacuum leaks, and now I have no vacuum leaks (I'm pretty sure). So I used a sealant that doesn't harden around the airbox and made sure the carbs were on tight because in the past I think they are and they are not.
So finally today I took off the airbox and observed how terrible the engine bog was with no air box at all. So... I plugged one of the airbox intakes with a rag completely and the other I covered 30% of with duct tape. The bike runs great now. I have low end all day, it starts great, and I have high end all the way up the RPM band.
SO whats up?? How can I fix this the real way??
