Re: Project Gretta....something's in the water....
Dunno about any of that Troy, I feel pretty certain that I did my research and found nothing....BUT, you should know that generation 2's parts are in hand, and are destined to go on BTC. You'd better believe you're getting one! It's only right, the phone consults were enough payment for that!
Today I got all of the gauges wired, soldered, heat shrinked, and mounted. They are perfect. It looks like I maintain about 13.7 volts at idle with the oil pump running. I can't believe it, but damn, this is gonna work. After about 15 minutes of idle and intermittent revving, the temperature (mind you it's sitting still and not moving air through the cooler) never got above 220 degrees F. That's awesome. All the while I get the peace of mind that she is getting constant oil lubrication directly to the cam and the rockers. I will eventually replace all of the oil lines with copper, but for now I'm working the kinks out. All of the new gauges are electronic, including the tach. They are all rubber mounted to the trees to prevent vibration, cause Gretta likes to shake that thing! The oil temp gauge runs a single pickup wire going to a sensor that mounts in the oiling manifold right above the valve cover. It's nice and clean. The oil pump switch is installed in the new gauge bracket and works beautifully. It's actually a vintage Lucas switch that I picked up from Barber's last year. Nice patina on there. I'm getting a little misfire on the left cylinder leading me to believe that the timing needs advanced a hair on that side, so tomorrow I get to splurge on a new timing light since my Harbor Freight version crapped out on me today. It was a good light....made it to WV and back, and then I dropped it today and no more working for her. Oh well, I wanted one with a dial in advance feature anyway!!!!
I have to do that, and then I have to build a dual fire adapter for the electronic tach. This allows the tach to sense the pulse from both tachometers without backfeeding the signal through the wires and causing a mis-fire. I bought the resistors and the diodes today to build it, but haven't made it that far yet. Those of you at Troy's remember how the gauge jumped around like a spastic when it idled because it was running off of one coil only....w.ll tomorrow, NO MORE! Then the cockpit will be complete. So for your viewing pleasure, here's what you see whilst grinning 'neath the helmet and goggles. Pretty sexy if I do say so myself.
Here's a lighted view so you can see the oil pump switch installed:
And all lit up in Batman mode:
And with headlight on to get profile.
This I thought was funny. I separate all of my pictures in photobucket by date. This was taken on 9-23-09. Time flies brothers!
Hope you dig it!
Hope you dig it!
