cushion drive for a spool hub
xb33bsa
Over 1,000 Posts
pretty self 'splanatory i wanted a cush drive on my SL/CL 350 hybrid so i cut off the cush drve of a yamaha dt hub and adapted it to the barnes hub that i am using
pics pretty much show what was done not shown in the added on hub is the bearing but yes it gets a bearing
pic 2 shows the majority of the machining, spoke flange removed and a register machined to fit the barnes hub
also i got rid of the cast iron center in the outer sprocket carrier and machined a better fitting lighter weight plastic delrin core/insert
mo pics
