JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Got a piece of junk 1981 yamaha sr250 that I decided to play around with. I couldn't decide on a paint scheme so I chose the boring route and went all white. I will be posting progress pictures of the build.
174.6 KB
193.5 KB
182.6 KB
Before and after polishing
164.7 KB
102.8 KB
Holes drilled in the cover and the front and rear brakes
175.9 KB
139.3 KB
185.3 KB
Using Duro HF904 dual sport tires.
Front 18x4.1 and rear 130/90-16
223.4 KB
179.5 KB
New parts from dime city cycles
246.3 KB
244.9 KB
Mini LED turn signals. Extremely bright for the size
218 KB
188.7 KB
249 KB
268.8 KB
Case splitting and cleaning
256.7 KB
225.9 KB
181.9 KB
127.4 KB
165 KB
Decided to add a kick starter to the sr250. Found all the parts needed
255 KB
Found a rare 1971 suzuki t125 stinger fuel tank. Little rusty so I am soaking it in vinegar and then using Caswell sealer
156.9 KB
174.3 KB
166.1 KB
216.5 KB
152.2 KB
160.2 KB
149.5 KB
184.7 KB
232.4 KB
188.6 KB
Using an old yoga mat for the padding. I'm also attempting to sew my first seat
169.7 KB
195.6 KB
176.1 KB
81.4 KB
223.8 KB
236.7 KB
225.6 KB
I found an extra sr250 swingarm and decided to extend it 6 inches. Here's a comparison of the original vs the extended
205.8 KB
An extra suzuki t125 tank I had. Wanted to see a different color on it
191.6 KB
205.6 KB
189.3 KB
199.7 KB
207.6 KB
Rebuilt the forks with new seals and also added an external spring to help stiffen the front up
274.5 KB
177.9 KB
Found an old 1960s headlight with speedo. The mini speedo from dime city cycles fits perfectly.
220.8 KB
180.2 KB
190.3 KB
185.4 KB
Laced up the wheels which was a pain in the a$$
214.5 KB
226.8 KB
145.3 KB
180.1 KB
227.8 KB
237.4 KB
