slikwilli420
Alright, so I'm a sucker for punishment and when opportunity knocks, you answer! There was a member on the SOHC/4 forum that was going a different direction with his Rickman project and I had a chance to buy the leftovers. In addition to what is shown here I also got the front mud guard and the chain guard.
There is very little information on the specifics of the kit or about reconditioning these parts that I could find. I will use this as a place to document progress on the restoration of these parts but also add details that one could not find without handling these parts.
It seems this is the earlier of kits in that it has the aluminum hubs with Borrani rims, whereas later kits had Ronal 5-spoke mag wheels.
Here is the rear wheel. Both sides of the hub have similar dimensions and the bolt pattern is the same, although the sprocket side is offset further from centerline. Both sides fasteners came apart really easily with some judicious PB Blaster use.
Front wheel has the same bolt pattern for the rotor as the rear rotor and sprocket. The front cast iron rotor is clearly larger than the rear but of the same design. I have gathered that these parts were very likely made for Rickman by Girling. This is the single disc hub version.
Aside from some surface rust, the rotors are both in very good shape. I am hoping I can get them resurfaced enough to get rid of any pitting on the pad surface. The sprocket is in very good condition and looks like it was used very little. It will still be replaced but at least I have something to take dimensions from.
An original set of Tommaselli clipons, in 38mm. While not part of the kit, they will look the part on this build and are a rare vintage part in their own right.
Original CP 2292 rear master cylinder. Its missing the cap but they are still available. The rebuild kits are still out there as well.
The rear caliper stay. I have seen a few permutations of this part, some with holes (likely not factory). Most are this variety, but I have seen some with shorter torque arms that are under the rotor instead of on top.
Front and rear calipers. These are the original CP 2195 units. You can see both are the same 'hand' version. If this were a dual disc version, the second front caliper would have the brake line input on the opposite end of the outer side. I am having some issues getting the second piston out of each caliper. I was able to get one loose with compressed air but the other is very stuck. I will have to adapt a fitting for a grease gun and see if that works. In the meantime, I will keep soaking the piston area with PB Blaster to try and loosen it up.
38mm Betor forks. This is the single disc version. From research I have done, the 38mm street version may have been the single disc one while any Rickman with dual disc was the 41.5mm fork. If anyone can shed light on this it would be really helpful. These will need complete rebuilding top to bottom. I will also eventually be sending the lowers to Jim F to be laser welded as there are some pretty big dings in them. These are also substantially (about 3") shorter than other forks of the era so I may end up sourcing some longer tubes, but that all depends on what frame I use and the desired geometry.
The top and bottom triple trees are the worst of any of the parts for condition. They appear extremely corroded, to the point that they have blistered and pieces are falling off. I think these are beyond saving but opinions are welcome.
That's all for now and as I get parts sourced to rebuild these components I will post here. I will also be leaning on the brothers here for a multitude of services to get everything as new where possible.
