CB750 No Plunger Hellride Freedom Machine
Re: CB750 No Plunger Hellride
doc_rot said:
I'm digging that 19" rear wheel
Thanks, Doc. It's a different look for a chop, but I like it. One caveat, obviously, is the lack of tire options which is why I went medium compound flat track for a fatter tire. Avon makes an rear tire (AM7 4.00-19) that I may try next. It's a cool looking vintage tire with more of a square patch. The only other options I've found are a Metzler Block-C (3.5-19) , Avon MKII (3.50-19) and the Avon Roadriders (3.25-19), which are front/back tires.
are you slacking?
its been like 6 days without an update.
Unacceptable.
HURCO550 said:
are you slacking?
Unacceptable.
No one wants to pay me the money they owe me :( , so I'm broke. I found a DR350 cush hub though, that a guy is sending me for the cost of shipping. :D
If you need the sprocket carrier hub for it.. I've got one
Thanks! He said he thinks he lost one of the rubbers. Do you have those too?
Damn you work quick. That's a good looking chopper you've got coming along there sir.
Thanks, John. It's somewhat stalled for the moment. I have some decisions to make and they're making movement slow.
I expected this to be finishes by now.
And then cut up into something else and that would be finished too.
Slacking
Slacking
LOL. eBay sellers are fucking slow to ship sometimes. I did, however, get my DR running again last night. It's ready for some Tennessee trails.
irk miller said:
I did get my DR running again last night. It's ready for some Tennessee trails.
DUDE YESSSSSSSSSS
I was able to get a DR350 hub from a member at ADVrider. I reached out to Buchanan to see if we can match some spokes.
Pretty slim. For some odd reason I've got the envie to put a set of spoke rims on my RD. Was looking at the KLR 650 stuff but have no ideas on dimensions on those.
Sent from my SAMSUNG-SM-G930A using DO THE TON mobile app
A little update:
Front brake is done.
I’m running a Z50 cable from the lever to the m/c. Then a 3an straight fitting instead of a banjo...
The caliper has a banjo to 3an fitting.
Then the top fork guard mount is altered (tabs removed) to accommodate a brake line guide. The line runs through a machined sleeve of black acetal.
Thanks, y’all.
A little Rub n’ Buff makes the plastic blend like aluminum...
