crazypj said:I'm about 99% certain you could fit an early XR 200 monoshock into 400f (or CB360 ) frame Swing arm is about 4" longer but being box section much easier to shorten if needed. Could also weld shock mounts on for a twin shock
jpmobius said:I find it very important to mock up the upholstered portion of the seat when I am deciding on the cowl shape. You can carve up an old seat foam to roughly fit and wrap it or paint it dark like the cover you intend to use to approximate the end result. I make mine from fiberglass with the seat base and cowl as a single component, so it is easy for me to shape the rigid foam for the cowl and soft foam for the seat at the same time. Looks like you can do the same thing adjusting your cardboard mock up with the seat foam until you get the shape of both to look like you want. I see an awful lot of bikes that would have looked a lot better if the upholstered portion didn't look like the separate project it was.
Integra99 said:Wow amazing work and story.. just spent 20mins skimming through.. !
Here's my cb400f so far.. mines very much standard but a few subtle tweaks.. waiting on the seat to be upholstered... money and time is a limitation with other projects.
crazypj said:I had no idea what a McIntosh C20 was so I looked it up. $3~4,000.00 for an amp, no wonder I never heard of them ;D
