Author Topic: LED Headlight Bulbs Finally Available  (Read 3696 times)
Offline el barto
Re: LED Headlight Bulbs Finally Available
« Reply #10 on: Feb 28, 2016, 12:52:20 »
Mine works super...Plug n play.
Bangin'!
Offline Sonreir
  • Moderator
  • Oregon
« Reply #11 on: Feb 28, 2016, 13:29:03 »
Seriously though, these look great. Has anyone got any reviews at all?
And Sonreir, do they plug straight in and away you go, or are there tweaks required to accommodate the LED?
Mostly plug and play, but if your headlight bucket is thin, sometimes some tweaks are necessary. I ended up taking a hole saw to the back of the plastic bucket to fit the light on my Duc. Older bikes seem to have less issues.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline Flugtechnik
  • My bike is not transportation, it is a respite
    • Nixon and Me
« Reply #12 on: Feb 28, 2016, 22:29:08 »
I've been meaning to leave a review here with some pics but haven't gotten around to it so here is a short one.
This thing is awesome. I have it installed on my '72 CL450 in an aftermarket bucket from DCC. Sonreir is right that your bucket needs to have some depth to accommodate it.
It is very bright, has a white color to it and is very noticeable. I happened to have my bike running next to a friend's XS650 with a stock light and the light from my headlight completely washed his out.
It lights up reflective signs very well. The quality of the light on the road is a bit different on the asphalt and I haven't decided if it makes it any easier or harder to see details, but I think it is certainly an improvement over stock.
The high beam is crazy bright.
Since the LEDs are only on one side, it only illuminates half of the bucket so it looks a little different and the throw pattern is different, but again, I'm not sure if it is better or worse.
I will say I have had absolutely no charging issues since installing it.
The only problem I have had was "ballast" plug coming "unplugged" once but it was likely my fault during installation and easily fixed. I think I have had it about 6 months now
I believe this is well worth the money, especially if you have a weak charging system.
end of line
Offline el barto
« Reply #13 on: Feb 29, 2016, 05:54:25 »
Thanks for the review Flugtechnik.
Sonreir, do you have any further information about the throw pattern and if this bulb is going to be legal in the UK? Tbh I can always use it on the road and then put in the old H4 bulb when the bike needs an MOT...
Offline Sonreir
  • Moderator
  • Oregon
« Reply #14 on: Feb 29, 2016, 12:11:52 »
Sorry, mate. Not sure about the legalities over in the UK. Over here in the US, I think it's "off road use only", but we don't have MOTs in most locales.
Offline el barto
« Reply #15 on: Mar 01, 2016, 10:48:40 »
No problem. Thanks Sonreir.
Offline Bama704
« Reply #16 on: Mar 01, 2016, 11:32:12 »
I as well have this set up on my bike.  It is so much brighter over stock.  The set up is super easy, I used the stock headlight housing on my kz900 and the h4 plugs right in.  It's a bit snug but have had no problems.  Would highly recommend.
1977 KZ900-A5
1965 Honda CA95 (Baby Dream)
Offline grcamna5
« Reply #17 on: Jul 28, 2016, 14:41:14 »
bump
Do your Best,no one can take that from you.
