Author Topic: Honda Twins - Three Phase Alternator Project  (Read 9463 times)
Offline Texasstar
  • Can't is a four letter dirty word
    • Zoom With Zeke
Re: Honda Twins - Three Phase Alternator Project
« Reply #50 on: Sep 12, 2017, 11:18:16 »
I finished up the soldering on the stator last night. I'll get it into the mail along with a new R/R in the next day or so.
Sonreir can you also make a harness from the stator to the reg mounted at the key switch and leave us 2' of red and green to mount to our fuse box?  Where we can be plug and play?  I can get you lengths and pictures later.
It's an optimization exercise and not a maximization trip.-Teazer
And though she be but little, she is fierce - WS
http://zoomwithzeke.com/
Third Times a Charm cb175
http://www.dotheton.com/forum/index.php?topic=66169.0
Honda Cb175 Victoria!
www.dotheton.com/forum/index.php?topic=52299.0
Honda Cb200 Lucky!
http://www.dotheton.com/forum/index.php?topic=45872.0
Bultaco El Montadero 360
http://www.dotheton.com/forum/index.php?topic=64349.0
Offline Sonreir
  • Moderator
  • Oregon
« Reply #51 on: Sep 12, 2017, 11:22:26 »
Yup. Just grab me some measurements and I'll have it ready to go.
Also, I'll be sending the 16 gauge unit. I discovered the wrong way to mount the new units when testing out the 18 gauge version, and the 18 gauge stator is no longer functional.  :-[ :-X :-\
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline Texasstar
    • Zoom With Zeke
« Reply #52 on: Sep 15, 2017, 10:15:06 »
Did you get the measurements? I put them on Zooids string.
Honda Cb200 Lucky!
Offline Sonreir
  • Moderator
  • Oregon
« Reply #53 on: Sep 15, 2017, 11:43:57 »
Uh, no. Sorry.
How long did you need the wires to reach? I'm looking for total length from alternator to regulator/rectifier.
Offline Texasstar
    • Zoom With Zeke
« Reply #54 on: Sep 15, 2017, 18:23:05 »
Uh, no. Sorry.
39" from alternator to reg/rec.  Then 2' for the green Red to the fuse box. Thank you!
Honda Cb200 Lucky!
Offline Sonreir
  • Moderator
  • Oregon
« Reply #55 on: Sep 15, 2017, 18:24:08 »
No problem. There's a black voltage sensing wire as well. I assume that will be running to the fuse box, too?
Offline Texasstar
    • Zoom With Zeke
« Reply #56 on: Sep 16, 2017, 11:17:42 »
Please
Honda Cb200 Lucky!
Offline Texasstar
    • Zoom With Zeke
« Reply #57 on: Sep 26, 2017, 09:50:07 »
Speaking of insulating. Does this fuse panel need to be insulated also?
Honda Cb200 Lucky!
Offline Sonreir
  • Moderator
  • Oregon
« Reply #58 on: Sep 26, 2017, 10:59:43 »
Not unless you plan on building a submarine. :D
12V is rarely enough voltage to short out due to moisture. The primary concern is corrosion, so I try to keep my electronics from totally inundated, but a bit of water now and then won't do much harm so long is it dries off sooner rather than later.
Offline Texasstar
    • Zoom With Zeke
« Reply #59 on: Sep 26, 2017, 11:58:15 »
Just want to make sure. Ok for testing purposes here is the current equipment
2 Morimoto Modpod LEDon low 160mA  on bright 580mA ea.
1 Morimoto Min Modpod LED 50mA on low 180mA
Total .37 amp on low and 1.5 amp on high
4.44 watts on low 18 watts on high.
https://www.theretrofitsource.com/led-lighting/daytime-running-lights/morimoto-mod-pod-led-lights.html
https://www.theretrofitsource.com/led-lighting/daytime-running-lights/morimoto-mod-pod-mini-led-lights.html
Honda Cb200 Lucky!
