HI everyone as you can tell im new here and im having some issues. I bought a 78 cb550 with open headers (i know they suck) and pod filters. well she starts up fine but at idle any rpm its blowing some black smoke and covering the right side of my bike in soot. I did also notice that one of the head pipes up close to cylinder is not as hot at the other three,even after replacing the spark plugs. Well i took the carbs off the seem pretty clean but i will clean them. The current settings are 110 main stock press in pilot, clip on the needle at the highest position(Furthest away from needle tip), and idle screws at 2 turns. FYI i have 90 mains and 120's that came in a box with the bike. ill also check the float levels, if i can remember correctly you measure from the end of the float opposite from the piviot and up the bottom of the carb body and set 12.5mm, correct me if im wrong. So if anyone had suggestions on this jetting set up right now that would be greatly appreciated.
Thanks Pat
Thanks Pat
