irk miller said:The best way to test for leaky valves is to fill the chambers with isopropyl alcohol and look for seepage. There should be none. A little wetting of the edges of the valve is okay (not ideal), but no drip should be seen. And a leak down test is supposed to be done at TDC. That's where compression is important.
cardinal said:Nice job on the lathe fix! Curious if you feel that the lathe is still worth it after using it for a bit. Did you look at the cost of finding a used lathe? (oh and the bike project is rad too!)
crazypj said:The 'correct' way to do it is fill port not chamber. Filling chamber really doesn't show anything other than major leak, having head 'on end' and filling port shows even the slightest weep around valve. I use acetone, if it doesn't leak, you know it's 'good'
Nice work on the brake adaptor
