DonCamalot
My 77 experiences high acceleration when idling and when touching the throttle at times. Engaging the choke seems to help out the idle and random acceleration. I'm trying to get a synch tool from a mechanic. But he also suggested that the valves might need adjustment. Any advice what it might be?
Things i've done:
Check for air leaks (haven't found any as of now)
Check air filter ( brand new/stock)
tune idle and rpm needles ( got it very rich and then very lean, still same problem)
Check throttle cable (no obstructions)
That's all i have for now.
a crappy mechanic said he gave the carburetor a "service" however, based on the work he did and other lies he told me, I have no idea if he actually did or what he has done to it. So i didn't take it completely apart and cleaned as much as i could.
The major difference is that when it's cold, it idles and throttles well when it starts heating up and running the idle shoots up and hangs there (4-5k rpms)
Thanks in advance for your help.
Things i've done:
