Aussiedrew
Hi guys.
Nearly have my tune perfect with the VM30's on my CB400N. However, one problem which I haven't found a solution for is the choke (I know, enricher).
The bike needs them on to start when dead cold, which is fine. However, when I flick them on and then start the bike, it will kick to life instantly and rev up to about 4000rpm and if I don't touch the bike, after a few seconds it will start to choke up and get too rich causing the rpm to drop and then stall (too rich). Now, if I flick them on and start it, kicks to life and revs up to 4000rpm, then flick them off, the idle will drop instantly to something way too low which then stalls (too lean).
I can work around this by upping the idle and that's all good for starting cold but then it's way too high once it's warm.
So the problem I'm seeing is that the chokes are way too strong and providing far too much extra fuel when they're on, but if they're not on and the bike is cold then it stalls. It makes starting when cold a frustrating procedure.
So, is there a way to lessen the effect of the chokes? Like, change a jet or block a hole or something?
