Okay, so my engine was leaking a lot of oil at the top end gaskets and tach drive gear, so i just decided to take the engine off the frame and replace the gaskets.
After reading my service manual a few times, and reading some posts on top end rebuilds on here, i'm feeling a bit intimidated by all that is involved.
I thought i could only buy the gaskets, tear the top end apart, replace gaskets, and torque back to specs. but i guess there's a lot more involved.
So from what i've read, i should check my pistons and rings while im in there and valve clearance. Is there anything else to look out for?
What if i just replace the gaskets/o-rings, slap and torque all that back together? Is it going to help any, be worse, or should i just rebuild the whole thing if im gonna bother opening it up?
I'm a bit sketched out because it's my only motorcycle, and it runs decent, i'm just loosing a lot of oil. i wouldn't want to run into more trouble (and extra $$$) taking it apart... as they say, if it works, dont fix it.
