that is very cool when i worked for mobil oil a cupl years in the field as a gas technician which covered servicing the compressors we had all the different brands of magnetoes and the kits as all of the converted from diesel to natgas engines in the field needed spark ign.. they are a pretty simple device a mag and reliable as a rock ,almostsurffly said:ARD has shut it's doors.
He did make set ups for a few bikes.
They are the "more common" set up for the CB750, but many options are out there.
I have owned a few.
If anyone comes across one and needs help I would be more then happy to lend a hand.
I have all the part numbers and can rebuild them.
Will post some details as I rebuild the set up for the Seeley.
xb33bsa said:that is very cool when i worked for mobil oil a cupl years in the field as a gas technician which covered servicing the compressors we had all the different brands of magnetoes and the kits as all of the converted from diesel to natgas engines in the field needed spark ign.. they are a pretty simple device a mag and reliable as a rock ,almost
omgwtfbbq! said:The IO 360 still runs mags doesn't it?
surffly said:Aviation is always slow to adapt new tech.
surffly said:Next year the plan is to get my license and maybe even buy a plane.
I want to get back into aviation, but this time flying.
Used to work at a warbird museum and had a tone of fun!
canyoncarver said:Find a nearby skydiving center that is looking for an extra jump plane and let them help you pay it off. Cessna 182's (get a wide body if possible) are by far the most common jump aircraft out there. Stick an IO520 or similar and good climb prop, wing extensions and a good gull-wing style right door mod and you are in business!
