Re: 1962 BSA DBD34 Gold Star restoration (Gearbox is done)
Bumpthump, thanks for chiming in on Dave Woods, a member on Britbike forum posted some images of his work and it is beautiful.
My gear bush arrived, so I built the my ARRT2 gear box with STD gears. I will write up and link to a separate page with loads of images and information to make it easy for the next restorer.
I drilled the correct three oil holes in the new bush with a uni-bit and had The Engine Store of Winona http://theenginestore.com press and hone the new bushes. They did perfect work, it was done the following day for $27, thanks guys!. The mainshaft fits and rotated beautifully with no more gap or leaks.
Before. Mind the gap...
After, with new bushes, no more leaks!
Gearbox is done!
I also picked up an original OEM 7" Lucas headlight from a cool member on Jockey Journal. It matches my original headlight but without the massive crack right down the middle. The price was right, considering there is the same NOS Lucas light on ebay for $249 with one day to go in the auction.
Enlightening...
I made a large order from Lyford's and should see new cables, bulbs, ammeter, rear brake assembly and some other bits by the end of the week. It is beginning to look like a motorcycle and I am seeing light at the end of the tunnel. I still need to purchase a chain, chain guard, new 12 volt dyno kit and regulator, carb parts, battery, fuel lines etc and possibly a new front fender and stays. My cylinder head needs new valves and guides, the magneto and speedometer need to be rebuilt. Time and money....
Gonna spend some quality time with the Triton this weekend, cleaning, putting the carbs on and battery back in and am watching the weather for I think I can get the first ride of the year in on Tuesday. I cannot wait.
