1977 Honda CJ360 - Café SOS - Stage Two™
Sonreir
Oregon
DTT SUPPORTER
OK... I've decided to put an end to my old thread and start a new one as I consider the first part of the project done and the bike is riding and running well.
If you haven't read the thread for stage one, you can find it here: http://www.dotheton.com/forum/index.php?topic=19672
Stage Two™ is going to mainly consist of fixing anything that didn't quite work out from stage one as well as some general improvements. I'm approaching this stage with two extra years of experience I didn't have at the beginning of my first stage and I've spent some time thinking and planning.
I kinda wanted to keep you all in suspense as to what I had planned, but I decided against it. Hopefully it will be just as interesting to know up front and then see it come to realization. I know it will for me, anyway...
Stage Two™ Improvements (in rough order)
  • General fixes I deem necessary after running the bike for a while after the completion of stage one.
  • Replacement of the analog speedometer with a digital computer with all-in-one speedo/tach/temps sensors, etc
  • Racing style vent for the gas tank Done
  • Removal of stock foot controls and replacement with rearsets - '88 FZR rearsets ordered from eBay for $40
  • Upgrade to the charging system in order to allow use of more electrical gadgetry
  • External oiling system (including cooler) for the cam journals
  • Upgraded suspension both front and rear
  • Venting for the front and rear drum brakes
  • Replacement of stock steel wheels with shouldered aluminum rims
OK... first problem to deal with... Remove those zip ties holding my battery in place and get something better and more permanent.
Enter $2 leather belt from Goodwill.
First up, cut said belt into pieces and rivet to my electronics tray:
Next, strap the battery into place using the plastic clasp that came with the belt:
Finally, use a brass clasp (riveted to the belt) to finish things up. A spare bit of metal left from one of the rivets serves as a pin to keep the clasp from opening:
Though not shown in this pic, I went back and put the wires under the first belt section to help keep some tension off of the terminals.
A humble suggestion I simply bought industrial velcro straps from lowes. and put a couple thick cuts into the pan and laced it through them and around the battery.. You couldn't rip that battery off the pan.
How is the Battery for height? I think I will do a similar thing but I will use a sealed gel battery and lay it on its side.
That "is" a sealed battery. He can run that anyway but upside down.
Interested in your speed/tach choice if you've already done your research. I'm heading in that direction also, the digital gauge is One of those things I keep coming back to.
I'm currently working on getting onto the supplier's list for a company called TrailTech. They make a lot of gear (mostly for offroad use) and they have a couple of computers that act as speedos and tachometers as well as other functions.
I have one of these on the way to me:
http://trailtech.net/vapor.html
Hoping to resell some at around $110 (includes shipping) once I get the details worked out.
i ran the vapor on my ducati monster, it worked pretty good youll like it.
The vapor looks pretty cool, i might be down for one of those. I like that it doesn't have a bunch of indicators that we don't need (fuel level, coolant temp, oil pressure, oil temp) but you can add the indicator dashboard to get them.
Unfortunately there are a ton of super cool digital speed/tach combos for V-twins that only go to 8k on the tach...
I keep coming back to this guy too.
Koso DB-01R
http://www.amazon.com/Koso-Multi-Function-Electronic-Speedometer-BA018B00/dp/B0022XS6K4
I probably will at some point, just not for this stage. The front drum is adquate for now, especially after losing 70 pounds from the bike during the first part of the build. The venting should help keep fade at bay.
New gas tank venting system to help with fuel flow. I tapped the fuel cap and screwed in the one brass barb and the other (on the triple tree acorn nut) is silver soldered.
I got out for a 15 mile ride this afternoon. Bike felt great but I'm still getting used to this cam and gearing combo. The engine feels like it's loafing in 5th at 50mph. You crack the throttle and nothing. I had to downshift into 3rd to get any acceleration but it had that in spades once I raised the RPMs. I brought it up to 70 in 3rd and the bike just felt so eager.
Attached are pics of the plugs after my jaunt. Not really a chop as I wasn't holding the RPMs at any given point, but you guys are free to weigh in with opinions. They look a little dark to me. I'm under the impression that unleaded fuel burns cleaner than the old leaded stuff so I should be looking for a very, very light tan.
On the downside, I'm leaking oil (yes, again, dammit) from the head gasket on the right side and so I'll need to take it apart (yes, again, dammit). I think the culprit is the uneven milling I got the from the machinist so it'll probably go back to him so he has an opportunity to correct his mistake.
Shot of the head after the milling, for reference...
The visible scratch does correspond to the point at which the oil is leaking. Copper head gaskets are not forgiving.
Get him to use a mill in place of the table grinder/surfacer, Im a fitter and we use the table surfacer on hydraulic valve banks from time to time and they are very hard to get right! an overhead mill is the only way to be sure you get a good surface, the only reason we get away with the table surfacer is that the two blocks are oringed and so are a bit forgiving but a copper gasket has to have a good clean surface.
at lease you can reuse the gasket! ;)
On the topic of all in one gauges, I went with this option:
http://www.ebay.com.au/itm/Acewell-2853-Digital-Tacho-Speedo-Odo-Fuel-Trip-Meter-/300621516997?pt=AU_Motorcycle_Parts_Accessories&hash=item45fe7050c5
mounted it like this:
Oh and if you are having issue with power consumption I am just about to trial a HID headlight bulb (35w) as opposed to my current (60w/55w). Should give me a couple of spare amps...
http://www.ebay.com.au/itm/120811708851?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
I just scored some 1988 FZR 400 rearsets from eBay for $40. They're gonna take a couple of weeks to get here from Greece, but you can't beat that price, I figure.
OK... I took an hour out of my day to pull the head and get it ready to go back to the machinist...
... and it looks like clearances were a bit tigher than I first thought. I seem to have lucked out this time, though. There was contact between the exhaust valves and the pistons but it must have been very light. The valves are not bent and it passed an acetone test right after I pulled it.
When the head gets back to the machininst we're going to have him take a bit of metal from the edges of the combustion chamber and I'm going to break out the Dremel again so the exhaust valves play nicely with the pistons.
Also, I believe my hunch about the core being out of square is correct. The contact patches on the right side seem "thicker" than those on the left. We'll make sure that's dealt with as well.
