Jesterhead
xb33bsa said:no hagen would not be the top brand simply because they are unservicable you cannot refresh the oil or have the valving fine tuned
top shelf would be ohlins, fox or works performance, all servicable konis or ikons would be a good choice as well
it is a very light bike so you do need to get something that is sprung and valved accordingly
slightly longer is fine, like 1/2"
Thanks for dropping some names to get me in the right direction. Not sure if I'm willing to drop top dollar on shocks for a $600 bike, but I'll read up and weigh that decision for myself!
spurlock said:Longer shocks will drop the rear wheel a bit so just be sure that doesn't cause problems with the chain rubbing the top of the swing arm pivot at full extension. Also depending on tire sizes and front end mods you might end up with the center stand being too short to raise the rear wheel off the ground without a board under the stand.
-Bill
Awesome , thanks! Might play it safe and just go with 330mm shocks to get a little bit more length and not mess with the rear end geometry too much!
