CG 125 Engine running like crap after rebuild
killerbanjo
Poor English kid getting into bikes and loves it!
Hey all, I recently did a full rebuild of a CG 125 engine I had as the crankcases were damaged, the engine was running before the rebuild. I just cant get it to run well! Although I am OK with engine rebuilds I am not so good with carbs, and wondered if someone with more skills than me could help me out?
https://www.youtube.com/watch?v=-uJOmDeOrGw
Here is a video of it running on full choke (Black smoke out exhaust means too rich?) and you can see the bike just cuts out when the choke is off. Also I try revving it up with full choke and you can see how that works out.
Many thanks!
PS please note this is in an XL 125 and has a bigger bore exhaust than a CG 125...
Carb needs a damn good clean out, pilot system is probably blocked.
You will need slightly larger main jet to compensate for larger diameter exhaust but low end needs fixing first.
