77' CB550F w/ 06' GSX'r front end/ Frame mod and MOTOGPWERKS
Tews19
Active Member
Here is my current build. A 77' 550F. Typical non runner story. 8k on the bike.
Parts collected for the build.
06 GSXR front end complete
benelli mojave tank
rear hoop bent
waiting for the motogowerks 4-1 to be completed but I have ordered
tapered bearings for the conversion
650 cam for a little oomph
new wire harness
I am sure I'm missing something..... I started a thread on sohc as well.
I am still debating on doing a mono shock for the build..
Re: 77' CB550F w/ 06' GSX'r front end
Here are a few pics of her current state amd previous work.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
More pics
06 hayabusa rotors
More pics
Love the spoked wheel with those forks, well done so far
Thanks guys. Hopefully I can have the wheel mounted soon. I need to figure out the plan with the hub.....
Has anyone used the stock gsxr controls for a build like this? I want to use the stock controls and mend to the stock wire harness....
Also I'm new to the site. How can I get emails for threads I've started or commented on?
To get notifications, click on the NOTIFY button a couple in from REPLY. You can also ADD BOOKMARK and keep a list of favorite threads in the MY BOOKMARKS main menu selection at the top.
I have a Honda front hub in a late 90's GSXR front end. A friend made me an axle to sort it all out. Bearing choices for the Honda hubs are sparse - biggest axle you can put in is 20mm I believe. So it takes some machine work to sort out the spacers etc. you need to mount up in the USD fork.
Got my tank in. I read a thread about these being played out but I like the look. This isn't a direct bolt on. Some work needs to fabbed up to mount.
77' CB550F w/ 06' GSX'r front end/ benelli tank in 7/11
Awesome build. Love to see modern front ends put on these old bikes. Following this project. Keep it up
Re: 77' CB550F w/ 06' GSX'r front end/ benelli tank in 7/11
I'm in. More detail on the 06' GSXR front end swap?
Re: Re: 77' CB550F w/ 06' GSX'r front end/ benelli tank in 7/11
Direct swap as far as the stem goes. I ordered the proper bearings from All Balls. Had to remove the races. The lower race on the gsxr was a pain though. Only way yo remove was to dremel it off. Other then that it was super smooth. Now to get the front wheel mounted properly.
Did you try one of these bearing separators for the lower race on the stem? I still have to remove mine, and this tool is sitting waiting. I used one to remove the end bearing on an XS650 crank. Works like a charm on bearings, but not sure how well it is going to work on a race which might not have a lip to get started under.
I've dremelled off a few races from stems too, to that's plan B.
Thanks. The stem is what I was curious about. That's one more bit of info toward my own build, stalled but research is half the fun. I had to dremel off the lower race from my 550 last night. The tool Tim posted sure looks easier.
I am not sure if the tool tim has shown would work. Ive swapped out all balls tapered bearings in every 550 and 750.... I was always able to use a long punch to temove the lower race on the stem. The gsxr one had nothing to grab on to. The dremel took less then 5 minutes as I went slow.
Freeze the stem and heat the bearings in thw oven at 185 for 10 min. Helps with the install....
Quick update.. got new parts in... rear sets. Aluminum rim with new spokes.... MotoGPwerks 4-1....... my seat mold....I may have it redone..Started the frame modification....
More pics.. Also have my Harley 19" dual disk hub.. Off to the welder this week to finish the frame.
R6... but I won't be using. I should list them for sale soon.
