fried connector on regulator
doc_rot
Oh the usual... I bowl, I drive around...
DTT SUPPORTER
DTT BOTM WINNER
Would a fried terminal on the ground wire from the regulator/rectifier be a symptom of overheating?
a bad connection will over heat a wire and fry it
as will to high a load over a period of time fix it and do some measuring and checking
what would i check for?
check charging voltage see if you are over or under
check for any warm spots in the harness indicating high resistance
contact matt at sparckmoto.com ask him for some ideas he is a wiz with this
Yes, it is a syptom of the connection overheating. Which is caused by too much current or too much resistance.
Which can be further broken down.
If we're talking about permanent magnet alternators, a fried ground wire is usually caused by one of two things.
[list type=decimal]
[*]Too much resistance caused by a substandard connection (e.g. corrosion in the wire or terminals, loose connections, etc)
[*]Decreased power consumption by the motorcycle - Removing lights (or turning off lights on a bike that is used to having them on all the time) or swapping out to LEDs will cause the motorcycle to require less electricity. The excess electricity has to be shunted to ground, and that might be more than the wiring or R/R can handle in its stock form.
[/list]
If your problem is the first item on the list, then cutting the wires, stripping them back to bare copper, and replacing the terminals is usually the way to go. A new R/R is sometimes, but not always, needed. www.vintageconnections.com for all your wiring needs. ;)
The second one is a little trickier. You'll still need to replace the bad terminals, but you'll almost definitely need a new regulator/rectifier and sometimes additional wiring to help handle the current. For instance, an upgrade to a MOSFET regulator/rectifier is advised: http://www.sparckmoto.com/Products/Detail/103
I would run a second ground wire as well.
A MOSFET still shunts peak power across the stator winding. A series style regulator doesn't shunt. Compufire 55402 is the best option, but comes in around $150 at most places (Amazon), but show up on eBay for around $60 https://www.ebay.com/i/112763988139?chn=ps. Series type also run much cooler, since the shunting is where the heat comes from. Shindengen SH775 is one used in a bunch of Polaris stuff. Shindengen makes most of the MOSFET style, so they use the same body and connections on their series type.
Yup. The SH775 is the one we stock.
[list type=decimal]
[/list]
The connection was a new spade connector that seemed to be tight and crimped correctly. running all lights , including running lights, which are incandescent except the headlight which is 35watt HID so I think power draw is the same as stock. I will re-crimp it and and keep an eye on it.
