Re: '75 CB550K Gulf - plugs, plugs, plugs
Hey man, check out a straight (or angled) die grinder with a 1/4" arbor. Cut off wheels for those are much cheaper, plus you can get the roloc (3M brand) buffing pads and discs for them as well. Also, you can get the carbide burrs, stone burrs, and wire brushes for them. They are air operated, so will work your compressor a little, but much, much faster at things than a dremel, and in a lot of cases, just as accurate. I can show you one of mine if you stop by the shop. I don't even own a dremel because of these (though the dremel will do fine work better).
