alzcbz
I'm putting together a café cb350. I would like to run an 18" rim.
I have CB350G front wheel with caliper assembly. The PO has tried to drill out, I assume, a broken bleeder valve. It doesn't leak, but there is no way to bleed the brakes. I have no hoses or master cylinder.
I have a CL350 front wheel with drum, 19". The drum is marked with 345, and the pad ID is 178mm.
I also have a, I believe to be, XL front wheel with drum, 21". The drum is marked with 340, and the pad ID is 160mm.
I would like to use one of the drum hubs mated with the 18" rim. How do I go about figuring what length spokes I would need? Or is my best option to run the front disk and source a new caliper and the associated MC and hose?
