neevo
Over 1,000 Posts
bikeboy said:mounts will fit. 900 shocks are 365mm long. Any help?
Is that the whole shock body? If so exactly the same as the stock 400 shocks.
Not going to help with raising the rear but sounds like a straight swap.
neevo said:Is that the whole shock body? If so exactly the same as the stock 400 shocks.
bikeboy said:that's centre-to-centre mounting holes
bikeboy said:wow. I've never seen a failure like that before. Very interesting ;D
Oh. and the sandblaster will be your new best friend
ian
neevo said:Any DIY solutions for a cabinet?
bikeboy said:where does it stop
neevo said:The lawn and my lungs are not coping with the blasting and I still have the engine cases to do.
bikeboy said:At the very least, you should have a good respirator/mask?
