I am about to rebuild the engine on my 1974 Kawasaki G3SS. The previous owner managed to seize the piston in the bore. Luckily the bottom end is fine I just need a new piston and ring set. I know that Kawi changed the piston height around 1975 by 7mm, Can any one point me to a reliable source for a piston pin rings and small end bearing? I want to go 1-1.5mm over sized. Or can I get a piston from a 100 and bore 2.5mm over?
