Habanero52 said:Did you cut these on a water jet or laser?
Maritime said:I Think he cut them by hand from the looks of the drilled corners. Nice clean work if so.
Habanero52 said:WOW!!!! Nice job!!!
Green199 said:Im thinking of leaving the main mount for that plate (the one closest to the swinagarm bolt), trimming the plate so it fits onto their but doesn't wrap around the frame rails, and welding it on in place. That way, I have removed about 3/4 of the weight of the plate (replaced by the weight of my rearset brackets), and because it is now welded solidly to the mount and rails it would have more structural integrity than the original bolted plate.
So effectively, I would only have the section drawn in red below.
The only thing is I currently cant remember whether the plate needs to be removed for any purpose so I shall check in the garage today.
DohcBikes said:There is no such machine as a gasless MIG.
MIG=Metal Inert Gas. You are referencing a Flux Cored Wire Feed welder.
Buy a MIG/Flux welder. You don't have to buy all the gas equipment right from the start, just buy the welder and run flux cored wire until you can afford a bottle, gauges, etc.
JustinLonghorn said:You can get good penetration with Flux-core, but it is a messier weld. Throws slag all over the place. Nothing a grinder can't clean up.
