CB550 78' "KUBATON" cafe/brat type
Quick question, did you sand back any paint on the mounting points between the engine and frame? It's best to be bare metal, so that there is a good earth between motor and frame, some then coat the bare metal with dielectric grease to stop corrosion.
That had popped up in my head as well. The two main bolts I'm sure have no paint contact. They have a clear connection and should be usable for a ground. Something I'm noticing on re-inspection. The battery is not steaming when the key is in on position just when switch is flipped to engage starter. Also battery lost power way too quickly (one or two minute span of tme). Battery before placed on bike read 14.3V. I'm going through the system now with voltmeter to check for major variances.
Ended up figuring out battery issue. I was pulling to much current apparently by having two leads directly off the battery. I've moved one of the leads to the post on the solenoid that the battery + leads to. System is now functioning normal. The battery is showing 10Volts and seems to be functioning fine now. But i am wary. More tinkering scheduled for tomorrow and hopefully my first start of the engine.
GOT THE MONSTER RUNNING TODAY! That sound when when the engine engages after that long haul of work is one of the best out there! Sounded great nice hum, louder or maybe it's just been awhile since I heard those pipes. Had a bit of smoke come out the exhaust. Hoping its just the engine "cleaning" it self. Was able to start 3 times in a row, which is promising as well. Had to stop as I want to break in the rings properly at running speed and I had an oil leak from the custom filter I put on her. Seems just to be not tight enough but if anyone is running one of these and has insight, lmk. Think I might have to go buy one of those adjustable belt wrench type thingy ;) Filter pic below, is leaking between filter attachment and honda oil filter. I've read Soneir's "starting a new build for the first time" and am following those tips. The smoke worries me a bit but have seen much worse from these bikes. My next step is to tighten/fix leak. Then I'm going to go back into the electrical system and make it a more permanent one. Next to refit a slimmer seat and possibly but a KZ cafe end on it. From the pics below I think you'll start to notice a lot of small custom paint/pieces I've got started. Custom horn/headlight/tank/see through points cover and more I haven't started.
In the middle of a full break down. First time I've attempted taking down a rear wheel. Having trouble with the tabs holding the sprocket cover. (pic below). Am i supposed to bend these back to get at the bolts or turn them some how? Or just try to ratchet/wrench on the nut and turn them out?
bend them a bit first with a screwdriver,so that smacking a socket with a mallet flattens 'em out ;)
why are you taking that apart ?
OMG, you have PD carbs :(
They are almost as bad as the 1979 CV's on 750/900
Have you trawled through SOHC4 to get jetting sorted?
Haha, yeah when I first got her. Actually i have two sets. One a self set (that i'm polishing and painting) and one that's on the bike. When I got Carpy's pipes I asked him what he recommended for jetting and it has worked pretty well. But running a bit rich. I'm sure once I get through this rebuild I will have to re-jet though because of the over bore i'm thinking. Not looking forward to that at all.
I'm going to be following up with pics soon of everything I've just done, as I put her back together. It's pretty extensive.
I do need recommendations on a welder. I've never owned one before. I have torch stick welded. 120V so I can use it at home. Something cheap, basic and something capable of welding 16g aluminum. MIG or TIG? recommendations appreciated.
If your intending to do aluminium, it's going to be expensive.
You can use MIG on 'thick' stuff around 16g but it needs to have a DC square wave setting
TIG would be nice but learning curve may be a bit steep if you haven't used one before or used O2/Da (oxyacetylene)
There are a few experienced weldors on here, maybe one will turn up with better suggestions? (correct English, Weldor is person, welder is machine ??? )
Guys need a little help figuring out the wiring for a reg/rec. I pulled this one from a junk yard parts bike for $10 yesterday with a guarantee that it would work. I think I've got the just of it, but want to double check before i go plugging it in an possibly ruining something. The pic below is the rec/reg from looking at it and research here's how i think it should wire?
from reg/rec-
3 yellows- go to corresponding alternator yellows
1 blk wire- coming from rec/reg is plugged to white from the old alternator plastic plug so will leave it like that (thats how it was set up on parts bike, pic shows this)
1 grn from reg/rec, prolly a ground
that leaves me with-
1 white/red- Im guessing this is power/juice Im thinking it would go to the solenoid?
1 black wire- which had a signal relay at one end 9as you can see from pic) so will use that for signal power
1 white- I've got no clue on this one? help
Any help in the right direction appreciated, thank you
That reg/rect won't work, it's for a permanent magnet alternator.
You have an electromagnet alternator so need a different type with 2 extra wires for field coil (called that because it creates magnetic field)
The black wire is live with ignition on, battery reference voltage
Got a new Rick's reg/rec in today and going to wire it up. Bought it from 4into1.com and really have to say everything I've ever bought from those guys has arrived supper quick (two days) and is exactly what was described. Would like to double check how the wiring from the unit should hook up. Unit came with a pin hook up (no idea why they would put a pin attachment that doesnt match up with the pin on a stock set up but oh well ;) which has 3 yellow wires, 1 thicker green, 1thicker red. It also has three separate wires green/white/black (prolly the regulator portions) Below Im going to show how I plan on hooking this thing up and if someone would double check it (CrazyPJ) I'd appreciate it. After I've done it and tested it I'm going to start a separate topic titled "Ricks regulator rectifier install on cb550" , as there is almost nothing on the web for this and Rick's doesn't send much in info as to how to connect.
reg/rec
3 yellow wires- connect to three yellow wires coming from engine (i gather that which connects to which doesn't matter in this situation)
1 thicker green wire- (which came in the pin formation) connects to green wire coming from engine at pin junction
1 thicker red wire- connects to the solenoid's smaller pos wire (not the plugs but one of the two smaller wires)
1 (thinner) white wire- connects to the engine at pin junction with corresponding white wire
1 (thinner) green wire- grounds to the frame
1 black wire- from research everything tells me to connect it to the ignition (this is the one that is throwing me for a loop, if someone could elaborate as to what this connection actually does I would appreciate it. My aim is not to just plug and play but actually know how the motorcycle functions completely) If I'm thinking about this correctly this wire would attach to the main "back bone" wire of the harness or whatever draws the most power (head light).
Also from the other pic I've posted you can see how i've set up my battery box. In wiring this thing I figure there are two basic ways I can do this 1.) one set it up similar to stock. Dont run a ton of fuses, wire one main "back bone" wire and power most everything like that. 2.) because i've got that pretty awesome fuse connector run everything separately. I.E.- run coils, headlight, turn-signals, tail all on different fuses. My question is which is the best way in your opinion?
The black wire is a reference voltage to control power on the white wire.
If voltage is below certain point it switches power on to magnet
When you turn on ignition, you create an electromagnet in the center of generator.
Use a small screwdriver to check, just bring it close to generator cover, it should 'stick' if things are working properly
Been working on her all day. Very close to finishing. Crossing my fingers that i've addressed the oil problems from the last start up. Finishing tying everything up tomorrow, running tests and finishing the seat. Pics are with the original tank this time, not happy with the paint job on that one and will have to be redone.
Here's how she sits right now. Completely wired, starter engages, ready to go except for two set backs. Carbs are leaking a ton and seat is taking me way longer than I anticipated to shape. Have to fix carb leaks before i'm comfortable test firing her...one more week.
